Hey GHQ gurus!
Are there visible differences between the M4A2 75mm models US-99 and R-69? Hoping to get an order up next month after remodeling the bathroom.
Bruce
M4A2 Models
If you're asking about the newer versions coming out, then yeah there will be visible differences. June's release will not have sand shields, while August's release will.
If still unsure what they look like, got to UK WWII tanks, look at UK-16 and UK 57, both have sand shields on them.
Doug
Bruce Lee
Bruce Lee
I believe they are simply placing the M4A2 in both the US (for the USMC) and Russian lists, while they are putting the M4A2 with sand shields on the British list.kiasutha wrote:Yah, but the question is about the difference between the US and RUSSIAN versions.
Seems they are doing 3 versions of it...
That is my interpretation. Perhaps we will get the full answer direct from the source on Monday.
Could be; that had occurred to me too.Mk 1 wrote:I believe they are simply placing the M4A2 in both the US (for the USMC) and Russian lists, while they are putting the M4A2 with sand shields on the British list.kiasutha wrote:Yah, but the question is about the difference between the US and RUSSIAN versions.
But it would be a departure from past practice; IE look at the Romanian list where "foreign" gear is listed, but under their original codes.
Same goes for Hungary in the printed catalogue, tho they haven't added them "on-line"...
Time will tell, I guess.
Turrets
Tammy,
Thanks for the info on the 76mm turrets. I had the same thought as AJ.
Bruce
Bruce
