Chrisswim Stuff.
Re: Chrisswim Stuff.
Mike, thank you.
Counter-battery radar, AN/TPQ-36, I made this with transparency sheet.
Remembrance Day, Armistice Day, and Veterans Day.
Thank you veterans. Have a blessed day and year.
VAB VOA, artillery observation vehicle. I put it on the VAB 6x6 vs. 4x4.
Install LMG on the front starboard side hatch. Cut off the 20mm placement. Put down round cylinder of styrene, then the housing from STUG 3. Cut barrel off with just a bit remaining to represent the viewing device.
VAB 4x4 w/ 20mm
Cut a tiny piece of index card to cover the opening for the LMG. Cut down a bit of the hatch on top of the 4x4, glue down 20mm.
VAB 4x4 w/ 20mm
Abrams AVLB
The US have tested using the older VLB on Abrams hull since thousands of surplus in the boneyards.
Bought these a group, tried to separate the bridge from the frame, hence the scars.
The bridges are not as long as the recently produced bridges, but don’t have to spend as much. Works for the US.
3-tone NATO 2 camouflage, Tamiya paints. It is commissioned. Need to work on a few more trucks M1078 & M1083.
Fuchs ambulance and communication vehicle
M113, old GHQ, they are smoke discharge vehicles now.
For the CV9040 AA, I used the CV9040. Get a round rod of styrene cutting it and then sanding it for round edges. Glue in center rear of the turret. Then elevate the barrel some.
The engineer vehicle behind it doe not have a turret. Put a crane on it, some parts or equipment ‘looking’ stuff on top.
Swedishmortar system
I used the CV90 hull paired with ‘47 Panther AA turret.
AMOS or Advanced Mortar System is a Finno-Swedish 120 mm automatic twin barrelled, breech loadedmortar turret. AMOS has been fitted to a wide range of armoured vehicles, such as the Sisu Pasi, Patria AMV and Combat Vehicle 90. Wikipedia
Skid-steer for those smaller jobs to help the engineers.
Repainted the Leopard 1, have a few more to finish today.
