Moderators: dnichols , GHQ , Mk 1
Posts: 992 Joined: Fri Jul 28, 2006 7:56 pm
Post
by Extra Crispy » Fri May 13, 2022 2:09 am
A post on FB got me thinking about vineyards (I don't own a single one yet). Had the idea of using roofing nails and scrubber pads. The nails become the "trunks" and then just flock the pads. For 1/285 the pad is easy to cut but I think thumb tacks would be the right length.
They are cheap and easy to make. I think once done they will flex over hills too. These nails are 1.25" so next time I'll look for something shorter.
Posts: 3823 Joined: Fri Dec 17, 2004 11:02 am
Post
by redleg » Fri May 13, 2022 3:54 am
Very nice!
Posts: 7279 Joined: Wed Dec 15, 2004 11:22 pm
Post
by chrisswim » Fri May 13, 2022 4:26 am
Are you making a vineyard or hedgerow?
Will it be elevated?
Post
by Extra Crispy » Fri May 13, 2022 5:01 am
Vineyard
What do you mean by "elevated?"
Post
by chrisswim » Fri May 13, 2022 5:26 am
In the last picture, there is space between the green and the brown. There is less metal exposed in the second picture as compared to the first.
Post
by Extra Crispy » Fri May 13, 2022 5:47 am
Just testing various "vine" thicknesses. I think the first is for 6mm with shorter nails, the second maybe for 15mm...
Post
by chrisswim » Fri May 13, 2022 7:28 am
Ok, thank you, I see what you are doing. Appreciate the explanation.
Makes sense.
Posts: 1083 Joined: Sun Feb 03, 2013 11:48 pm
Post
by BurtWolf » Fri May 13, 2022 10:40 pm
Cool idea - will be interesting to see it on the terrain board. I suspect moss or lichen is too big to use?
Post
by Extra Crispy » Fri May 13, 2022 10:49 pm
For 1/285, definitely. I use it for hedges and hedgerows. If you trim it it just turns into dust.
Post
by BurtWolf » Tue May 17, 2022 10:52 pm
Do you know of anybody who has 3-D printed hedgerows and then applied flocking to it? I’m wondering if that might be an easy solution as well?
Post
by Extra Crispy » Wed May 18, 2022 6:26 am
Timecast make them in resin
