All of this plus MTLBP, BTR 60/70 Command and Artillery versions, BMP command and recon as well.Splod wrote: ↑Mon Oct 25, 2021 5:12 amI whole-heartedly agree!pmskaar wrote: ↑Fri Oct 22, 2021 8:54 pmIsraeli 1. Infantry for 1967-1973.
2. Heavy Weapons for 1967-1973.
3. M-38 Jeep. Would have MGs and Recoilless Rifles.
4. 120mm Mortar on Halftrack and Sherman chassis.
Egypt/Syria 1. Infantry for 1967-1973.
3. BRDM-1 (New Sculpt) GHQ used to make this.
4. ZSU-57-2 (New Sculpt) GHQ does make this but it is an outdated sculpt, Also usable for Warsaw Pact and Vietnam.
Jordan 1. Jordanian Infantry for 1967.
2. Jordanian Heavy Weapons for 1967.![]()
I've just opened a pack of the ZSU-57-2 and was a bit blown away by how average the sculpt was. It's definitely showing it's age against newer releases. I found another hole in my collection over the weekend while converting a T-72 Bridgelayer to an MTU-20.
Cold War/Vietnam - Soviet/WarPac
MT-55 - T-55 based armoured vehicle-launched bridge (AVLB). Widely used by Soviet, WarPac and Arab forces from the 1960s to today. Bridge base is a two-part 'scissor' design.
MTU-20 - T-54/55 based AVLB. Widely used by Soviet, WarPac and Arab forces from the 1960s to today. Uses similar bridge to that found on GHQ's current T-72 bridge layer model, being a single span with folding ramps at either end.
This is the 2021-2022 Wishlist for the GHQ NEW PRODUCT LIST of 2022-2023
Re: This is the 2021-2022 Wishlist for the GHQ NEW PRODUCT LIST of 2022-2023
All true PG good points.
every man for all mens rights
all men for every mans rights
How about updating some of the support German WWII SdKfz half-tracks, like the models 3 and 11, to the Ausf. D model.
Mike
Mike
Modern US - M274 Mechanical Mule. If I want Airborne or Air Assault troops on the battlefield in a wargame, this is an essential. Yes, it's small. Get a copy of Tankograd's Reforger 76, in which 101st Airborne participated. You will see pics of these things laden with packs, 5-gallon cans, TOWs, and anything else they needed to carry. They also used M151s and M561s with all manner of "stuff" packed on. That's how we need them... Stuffed to te "gunnels" with gear, just delivered. It's time for something dynamic in the range, unusual. Give us the Mutt loaded up, too. We need 'em as they would be just delivered and ready to go. We don't need EMPTY ones! Look at that book for great examples.
My brother was in 82nd. As a company XO, he HATED them because I guess they were a bear to keep running. I just laughed at him. I had to keep tanks, Goats, and GOERs running!
Modren Russia:
MBT- T-80BVM
SPG - 2S25 Sprut-SD VDM
IFV - BMP-2M Berezhok
MRAP-Typhoon-K KAMAZ/URAL
9K720 Iskander (SS-26)
2A65 Msta-B 152mm Towed Howitzer
ChIna:
SPA- PZL -05 155MM
Dongfeng EQ2050 (Mengshi) 4X4
NORINCO CS / VN3C 4x4 Wheeled Airborne Light Armored Car
NORINCO PCL-09 122mm Self-Propelled Artillery
NORINCO Type 70 MRL (WZ303)
Modren Russia:
MBT- T-80BVM
ChIna:
SPA- PZL -05 155MM
Every knows if a goat was running it was on fire lol.
It would Be great to see some of the new modren Russian hardware I'm currently playing with the Panzer War/Air land ruleset to fight the current conflict in Ukraine vs DPR/RUSSIA and the 1995-2000 Chechen war. I also plan on fighting a hypothetical war Russia vs China.
Russia: 2S25 Sprut-SD light Tank for the VDV
Kamaz-K Typhoon/Ural Typhoon MRAP
T-80 BVM MBT IS A MUST HAVE!
2S35 Koalitsiya-SV is a self-propelled gun
BMPT "Terminator-2" OR BMP T-15 (Terminator -3)
BMP-2M "Berezhok" Russia and India have over 1000 on order and allso the BMD-2M
2S5 Giatsint-S 152mm SPG & 2S4 Tyulpan OR 2A36 Giatsint-B
US Modern
We must have the new US Marine Amphibious Combat Vehicle. With all the Chinese stuff GHQ has produced, this is a MUST!
Assortment - everything from M38 jeeps to M715s, CUCVs versions, the light and medium trucks of US units from the '50s, '60s, and '70s have been sorely neglected, ESPECIALLY in view of the plethora of HUMVEE variants. We need M37 utilities and ambulances, M715 utilities and ambulances, CUCV utilities and ambulances. These are all in the 3/4 to 1.5ton capacity range. They plated an important role in combat and support units, both in the Cold War in general and in Vietnam. Theu deserve representation. And I refuse to buy any more HEMTTs to stand in for GOERs! Don't forget M800-series 5tons, either.
The upcoming year should see FLEETS of wheeled support vehicles! And FIELD GEAR ADD-ONs for vehicles, as well!
Bring back the original M60.
I've just discovered that the only way to get petrol engined Mk.V Centurions with 20lb guns is to buy the Centurion Ben Gurion and stockpile the 20lb turrets. I need some early centurions with 105mm for my '67 IDF, but probably not enough to also outfit my Jordanian forces!
It's a similar issue I had with the M109. Luckily I only needed 6 M109 and I had a mate who was able to come through with some extra turrets for me.
- Douglas Adams
- Douglas Adams
Besides what has been listed in support vehicles bulldozer D7 or D9 or foreign equivalent. . DE based APD. DMS based on Gleaves class DDs
J W Bolen
You can buy the turrets separately, rather than buying the whole pack just to get your two turrets per pack. You can also check with Chris. He is a good broker for spares.
2nd that one. Would also suggest taking a modular approach so there is one base model that can have different tops representing the four different models.panzergator wrote: ↑Fri Jan 07, 2022 3:18 amWe must have the new US Marine Amphibious Combat Vehicle. With all the Chinese stuff GHQ has produced, this is a MUST!
Would be very happy to see one of the uparmored Israeli M113 APCs: Kasman, Nagman, Magen, Maoz. The other Centurion APCs (Nagmashot and Nagmachon) would also be appreciated.
Anything WW2 Italian.
