Canadian LAV III
shawno
Re: Canadian LAV III
Post by shawno »
Nicely done! I don't have what it takes to make LAV III's so I had to settle for coyotes. Have you given a crack at modeling the Leopard c2's with the MEXAS up armour package?
dougeagle
Post by dougeagle »
Sounds interesting enough. Is that pic an actual LAV-III from the net or is it the completed model that you have worked on?
Doug
Bruce Lee
Here is my suggestion.
First, I won an auction that had 10 LAV 25 turrets without the hulls. Then I used the Stryker CAV version and inserted the LAV 25 turret in the hole for the commanders weapon station. Worked perfectly! Now for 5 or 6 of these, I used the Stryker Cav dection/spotting 'box' and glued on left rear hull, on two i added telescopic pole to extend the device into the air for better survellience.
Any other good ideas?
shawno
Post by shawno »
chrisswim wrote:Here is my suggestion.
So with the LAV 25 turret, you can just drop it into the stryker cav no problem, or is it much harder then you make it out to be? Does it look proper?
Hey Cama, care to post a pic of your LAV III's?
Cheers....
Cpl_Blakeman
Post by Cpl_Blakeman »
cama wrote:1. Take the turrets out of N-68. Toss the hulls into you bitz box. A bit of waste, kind of sucks. Oh well.
You could use those LAV hulls for Canadian Bison APCs, which as far as I know are just LAVs without turrets. Could also use them for recovery or maybe mortar vehicles as well.
Drink water and live, don't drink water and die.
av8rmongo
Post by av8rmongo »
I think the Bison is more of an uparmored C2 version in that it has the same raised roof over the troop compartment.
shawno
Post by shawno »
av8rmongo wrote:I think the Bison is more of an uparmored C2 version in that it has the same raised roof over the troop compartment.
Having worked in them, this would be a more accurate description of the Bison.
Instead of putting the CAV hatch and machine gun & sighting. I used the LAV 25 turret. Pretty easy to me. Try it with out glue, see if you like it.
shawno
Post by shawno »
Chris sounds like you're describing a LAV III version of the LAV II coyote...any pics?
and chris did you dremel anything down?
shawno
Post by shawno »
cama, sorry to bug, but could you post that pic of your LAV if you have it handy? cheers...
Shawno,
I may be LAV II Coyote, just used Styker CAV hull & paired it with LAV 25 turret to replicate the Canadian vehicle as shown above in the post.
On the back left corner on the hull put the Styker CAV sighting/targeting box, glueing to the hull, two I have elevated for survellience.
I will try to work on photos.....
shawno
Post by shawno »
Great job Cama, good insight for me.
Thanks!!
