Magach 7A vs 7D model, M-60A3 Reactive armour vs Magach 6B
thenorthman
Post by thenorthman »
Hello all,
What do you think about of "filling" down the Magach 7D frontal armour on the turret to more vertical angle to be a sutiable substitue for the Magach 7A. Like to know what other think before I file down to a unuseable $1.79 (soon to be $1.99 :D ) tank. Some photo's to compare...
Then do you think the M-60A3 with reactive armour would be a good substitute for the Magach 6B? Maybe with the reactive armour "etched" into smaller blocks.
Sean :?:
Fireman Tim
Post by Fireman Tim »
EEEEPPPP! :shock: You are a brave man and I hope your eyes are good. Try one and have some green stuff on hand.
I would just plead with GHQ to make one. And while you are at it, ask them to make a Magach 6a (Since they did see alot of combat in Lebanon in 82)
Ben
Post by Ben »
Hi,
from what I know there (officially) is no Magach 7D in IDF service and the Magach 7D made by GHQ should be referred to as Magach 7C.
My 2 cents,
Benjamin
thenorthman
By golly your right...I didn't catch that.
Well then make the Magach 7C to a 7A is what I might try to do then.
Sean
Can also use the "Maglich 7D as the Sabre, with 120mm. Almost sloped enough, But most gamers will not know and those like you that do know, will not mind, I am sure....
