Indirect Fire - Plotting, Sheafs
Guys
I am a bit confused - how is Indirect Fire plotted?
Do you guess a range from the FO stand towards a point?
Do you get your opponent to turn his back whilst you measure towards a certain point?
Or what?
For the sheaf - is the angle of the sheaf based on the direction from the FO to the target?
Many thanks
Andy
Or what?
Many thanks
Andy
Can you give us a bit more on the context of your question?
Are you asking for how different gamers approach the question of gaming etiquette on this issue? Or are you asking about how it indirect fire is supposed to be plotted under a particular rule set?
Re: Indirect Fire - Plotting, Sheafs
No.ologotai wrote:Guys
Or what?
Many thanks
Andy
All your tanks are belong to us.
Panzer War rule system
Andy:ologotai wrote: I'm asking how is it meant to work.
How it is meant to work depends very much on the rules you are using. Some rulesets are quite explicit, others are not, and leave it up to the gamers to develop their own ettiquette on the issue.
I have perhaps a dozen different rulesets, and have played perhaps half a dozen more that I don't own. Their approaches to indirect fire vary quite considerably from one to the other.
So, can you give us a bit more context on your question? Do you have a particular set of rules in mind?
The sheaf should align with the line of fire. A gun's fire will generally be longer than it is wide. But with several guns firing into the same area they may add width but not so much length. So at some point from one to many the width of a battery may be wider than it is long. The direction to the FO has no bearing on the alignment.
Mortars tend to have a more circular area.
I am refering to GHQ modern, using Combined Arms.
Typically, I use the base line from which the arty is 'fired' from. This is after enemy unit is spotted, then laser range finder and plotted into the targeting computer, then transmitted to fire control direction team, and priority que. Once selected for firing mission, ammo type selected, range, wind setting, temp, humidity, etc., then into the battery sequence for mission and delivery to target. Evaluation of fire mission, adjustments as needed....
Is this what you are looking for? I do use GHQ, not sure what that has to do with a rule set or a concept. Hope this info helps. Would you like me to get Col Bill Everett in on this?
Plotting methods
John (as far as I know) never specified a particular method, but I've seen use players close to him, as well as general players use several methods. Here are the 3 most common I've seen used
1) designate 1 corner of the board usually the players near left corner as the base corner, then plotting proceeds from that point: so many inches up & so many inches over (right) from that point. This works really well for off-board artillery.
2) determine a perpendicular line straight out from the center-front of the base of the artillery model. Then designate so many inches forward & so many inches left or right deviation.
3) This method I've used when I've played John: from a readily identifiable landmark on the board (a specific building, crossroads --- not a tree in a forest -- & it must be in the clear LOS of the artillery or the forward observer or designated at the start of the game) give a deviation from that landmark by cardinal direction & inches from the center of the landmark.
For example: from the crossroads 6" north by 2-1/2" east. This of course requires that the cardinal directions were determined prior to the beginning of the game. This is my favorite method & works well in play. It also tends to keep units from clustering by obvious landmarks,LOL
skal,
Sven
skal,
Sven
Skal,
Sven
Sven
Although I have never played the current "GHQ Microarmor - The Game" ruleset, my approach to plotting artillery calls is very similar.Sven wrote: 3) This method I've used ... : from a readily identifiable landmark on the board ... give a deviation from that landmark by cardinal direction & inches from the center of the landmark.
For example: from the crossroads 6" north by 2-1/2" east. ...
I much prefer that artillery plots should be done by estimating, rather than by measuring.ologotai wrote: And do you guess the ranges - or measure them whilst your opponent looks away?
I like game mechanics that give a little feel for the real-life human factors, rather than relying exclusively on tables and dice. I doubt very seriously that artillery FOs get to go to their ordinal points and pace off (or even laser-off) the distance to their targets very often. There is a very real potential for human error on distances and directions when an FO puts his cross-hairs on any target that is not at one of his pre-registered aim points. If a little of that potential can be injected into the game without another die-roll, I say that's the better approach.
Of course, it helps if BOTH sides have the same appreciation for the value of injecting error. Not nearly as much fun when you accept the error, but your opponant wants to measure to the Nth millimeter before making any decisions...
You're welcome. As to ranges - having played Fletcher Pratt Naval Wargames & having to do ad-hoc construction for many years I am pretty good at estimating ranges. No the way you handle it is that you make your estimate without measuring & write down your indirect fire orders. For example "Red Brick building north of crossroads - West 8 inches, South 3.25 inches - 3 impact in east-west line" or "3 impact in North-west/southeast line center on crossroads". Then when the time comes later for the impact markers to fall, you & your opponent plot them out together measuring together.ologotai wrote:Thanks Sven.
Regards
Andy
Works rather well & minimizes disagreements.
Skal,
Sven
Skal,
Sven
Sven
