John Deere 9500 combine n-scale
This is a general forum for all types of posts related to N Scale models.
fedequoit65
Post by fedequoit65 »
I'm half done building this kit.
Regretfully the instructions to piece together the front end thrasher leaves a lot to be desired. Has anyone built this kit and can pass along any suggestions. Thanks.
Stumped in upstate NY (-jb-)
StarCruiser
Post by StarCruiser »
I don't have one to look at (outside of my chosen era). All I can suggest is to look closely at the picture in the catalog:
http://www.ghqmodels.com/store/54009.html
nmanica
Post by nmanica »
fedequoit65, Could you post a picture of the area your talking about, I'll check my stash
Of kits and look at it and maybe give you some tips, I've built about 6 of them and made them work.
N 8)
"Anyone can model prototypically,it takes a genius to model What If".
georged
Re: John Deere 9500 combine n-scale
Post by georged »
I too am working on one of the JD combines and am at the point where you insert the thresher into the blade and it seems that the whole thing is too long to fit. any help would be appreciated
georged
Post by georged »
i ended up trimming the two outside spindles down and then not adding the2nd stat at each end in order for it to fit.
StarCruiser
I don't check this board as often anymore, it's been pretty dead for some time.
NManica hasn't posted in quite some time (actually, getting a bit worried about that).
I haven't built that one since I'm mainly interested in the transition era and well, that's a bit too modern so...?
Sounds like you found a good solution anyway.
Evis19761
Post by Evis19761 »
Thanks for the answer!
