Paint Removal
Paint Removal
I know this topic has been done before, but I can't find a way to search this forum to find what I need quickly.
I need to strip some vehicles. Sadly, and might be changing it in the future, I use enamels. I have used Simply Green with some success but it does leave some paint in the cracks. Other times I has stripped really good and help from a tooth brush got the remainder off. I was hoping someone had a stronger product that worked good on enamels.
I think someone suggested Aircraft Remover. Is there a specific brand for this product and how well did it work for you? Just wanted to double check before I searched for it or ordered it on line.
Try Pinesol. I have used other paint remover, but the fumes and fire hazard aren't worth it. Recommend wire brush. You may have the use a needle pick, although it is obviously time consuming. Soak a week in Pinesol, rinse, dry, and work it immediately.
Duplicate deletef
pdxs3t
Post by pdxs3t »
Go to the local automotive parts store and snag a can of Aircraft Remover. Will strip any paint off metal in minutes, not hours or days.
Cama,
Just to be clear, it works good on Enamels? At the moment, its the main paint that I am using. A follow on question, does it work on Lacquers, and clear coats as well?
Thanks to everyone for the information provided in this topic.
P.S. Cama, please post some more of your handy work. Miss seeing it.
tstockton
Post by tstockton »
A caveat on acetone... it also dissolves plastic. If you want to strip paint off of a vehicle to which you've added styrene parts, it will also remove those parts.
Don't recall where I picked this up, but it stuck in my mind "for future reference".
Regards,
Tom Stockton
Tstockton,
Thanks for the tip. Great cautionary advice. Would be trajic if you did all that work and then have paint thinner ate them Way. Fortunetly I am not that gutsy to do styrene modifications.
pdxs3t
Post by pdxs3t »
If you really want to strip paint off a miniature, it can be done in minutes by using Aircraft Remover. Yes, it is called Aircraft Remover. And once you use it, you won’t use anything else for the job. I’ve used it to strip around 200 miniatures. It also works on plastic models too (test first just to be sure).
https://www.amazon.com/Klean-Strip-Airc ... nt+remover
pdxs3t,
I think i will start off with trying some of the Aircraft Remover. I have some WWII and modern stuff I would like to redo.
Thanks everyone for all the great suggestions. Keep them coming. If I ever get any time, I might try to go back through this tread and make a list of all the products and what they are good for. Not sure if that will happen, but we shall see.
Hoth
pdxs3t
Post by pdxs3t »
Let us know how well it works out for you.
