Cleveland USN 72
fullmetaljacket
Cleveland USN 72
Post by fullmetaljacket »
I just purchased 3 of these cruisers, question I have after looking over kit for several minutes, is as follows.
1. The AA tubs where do they go on the model? I see online pictures but on the kit I don't see any wholes to anywhere to mount them?
any help would be appreciated and pics even more thanks.
fullmetaljaceket
cinctim
Post by cinctim »
Hello fullmetaljacket,
It's been awhile since my early round bridge Cleveland's, (as well as the late, square bridge ones), have been out of the shipyard, but from the models and the directions I have the quad 40mm's are installed in 2 positions, both port & starboard.
1st Location is right behind the bridge side 5" gun housings, on the "stand" that is also
part of the bridge assembly piece. Note, on the starboard side, between the 5"
mount and the 40mm stand, there is a molded life raft, but that is not molded on
the on the port side, (at least on my models). This spot is also located to the sides
of the space between the foremast & 1st funnel
2nd Location is the square section/stand that is molded on the hull, just slightly over
1/16" behind the above previous "stand". It is also the square sections that are
between the two funnels, when both superstructure parts are in place, to both
sides. Note, this mount is lower that position 1.
I can't remember if my models had the holes in the stand tops or not, but if yours
don't, would recommend a few swipes on a file to remove the mounting pins on the 40's.
Hope this helps.
fullmetaljacket
Thank you very much appreciated.
fullmetaljacket
