Finally getting around to painting my UK-113 "Humber MK I" pack and while researching what colors to use I have discovered that the turret and hull are not a historically accurate combination.
The turret has the .50 vickers combo mount - this was only used on the GUY MK I armored car. The GUY hull is similar to the Humber MK I hull except that the rear fender/stowage slants downward on the GUY. The US-113 pack has a horizontal rear fender/stowage so it is correctly a Humber MK I hull.
The GUY MK IA armoured car had the turret with the long Besa 15mm HMG. That is the turret that should have been included with US-113. It is the same turret as the HUMBER MK II (UK-51). So easy fix, everyone will need to to get a spare gun sprue from Pack UK-51 to fix these. Then we will have a correct Humber MK I. They were first used in the desert.
Incidentally the UK-113 pack does make a passable GUY MK I armored car. If GHQ could tweak that rear fender/stowage it would be great!
Those served in France in 1940.
UK-113 Humber MK I turret hull mismatch issue
supertsar
supertsar
Re: UK-113 Humber MK I turret hull mismatch issue
Might as well pass on some links to my references while I have them up. War Wheels dot net is great.
The booklet "British Armoured Cars" by B.T. WHITE is old but accurate.
http://www.warwheels.net/images/HumberM ... w1-100.pdf
https://www.militaryfactory.com/armor/d ... mor_id=479
https://tanks-encyclopedia.com/ww2/gb/G ... ed-Car.php
https://tanks-encyclopedia.com/ww2/gb/H ... ed_Car.php
MechCommander
Did you contact GHQ about this? they might be able to fix the problem.
CG2
Last time I contacted GHQ about an issue, they never bothered to respond. There do seem to be more errors occurring than before so I wonder whether GHQ's research team has some less experienced people than it used to have.
CG2
